Activity Forums Maxon Cinema 4D Basic question: How to smooth a bezier anchor point like photoshop?
  • Basic question: How to smooth a bezier anchor point like photoshop?
    Posted by David Grush on September 26, 2014 at 3:12 am
    Ok so when I use the Bezier tool and I create a curve, as soon as I start a second line and it curves it automatically.
    In photoshop while using the pen tool, to fix this you simply Alt+Click on the anchor point.
    What is this action called as well?
    Thank you,
    – David
    Emir Bojorquez replied 11 years, 11 months ago 2 Members · 1 Reply
  • Emir Bojorquez
    September 27, 2014 at 6:59 pm
    While making a curve and without releasing the Left Mouse Button, press and Hold Shift on your keyboard and move.
    Also after you finish your spline you can edit the curves using the Rotate Tool.
    Good Luck
    Imagination is the best tool…
