Activity › Forums › Adobe Premiere Pro › Basic Question for Stability
  • Basic Question for Stability
    Posted by Matt Hannon on April 14, 2020 at 4:32 am
    Hey guys,
    I’m just about to delve into a feature doc with hundreds of hours of footage, something like 30k clips.
    Just wondering what people’s thoughts are on the Mercury Playback Engine in regards to the most stable settings (happy to lose a bit of performance if it means less crashing). I’ve seen lots of youtube videos etc recommending swapping to ‘Software only’ to reduce potential crashes – is this correct advice?
    Any other suggestions to make Premiere more stable?
    I haven’t had major issues with crashing (yet) but am about to begin the roughcut, so things may get complicated down the line.
    I’ve updated to Mac OSX Catalina (latest version) as well as updated to latest version of Premiere. Also running a simple 12TB external harddrive (backed up by 2 other separate units) connected via thunderbolt.
    2017 iMac 27 inch
    3.8 GHz Quad-Core Intel Core i5
    64 GB RAM
    Radeon Pro 580 8 GB Graphics card
    Thanks in advance!
    http://www.thunderboxfilms.com
    Merlin Vandenbossche replied 6 years, 5 months ago 3 Members · 4 Replies
  • Matt Hannon
    April 16, 2020 at 3:27 am
    Any ideas?
    Just in case someone else sees this, upgrading to catalina and the latest version of premiere seems to have sped up the opening time of the file and linking all the clips etc – also more stable there.
    Cheers
  • Santanu Bhattacharjee
    April 20, 2020 at 3:45 pm
    My experience – I stick to hardware acceleration, even if some effects crash or don’t render once a while. The agony of scrubbing through the basic things again n again during an edit is more painful in software mode.
    Only as a last resort, if my PC keeps crashing while my deadlines come close, I switch to software mode.
    Santanu Productions, Mumbai
    The Swiss Army Knife for All Your Creative Needs
  • Matt Hannon
    April 21, 2020 at 6:07 am
    Thanks Santanu,
    Yeah I have just left as is for the moment and things are running well. Surprisingly the update to new OS and software seems to have helped a bit.
    Hoping things dont slow down to much when the sequences start getting complicated later in the production…
    cheers
  • Merlin Vandenbossche
    April 21, 2020 at 7:43 am
    I understand when people “advice” others to disable the Mercury GPU acceleration as it sometimes helps alleviate problems that start at the GPU level, but it is generally bad practice to do so. In the majority of scenarios your GPU wont cause issues. I only do so when something weird pops up: when the program monitor shows weird green flashing, when I get errors trying to export or render a weird combination of effects. This will not happen often, especially on MacOS, where you do not control GPU drivers yourself. For people on windows workstations correctly updating GPU drivers usually makes those problems disappear as well.
    So always keep the GPU acceleration going as a standard operation. I see no reasons not to. It will help a lot with playback, especially once you start adding any type of gpu acclerated effects. And it will boost export speeds. If issues with exports or playback occur, think of disabling it as a possible workaround. But it will not cause more crashes as someone wanted you to believe.
