Activity › Forums › Panasonic Cameras › Basic Question About HMC-150
  • Basic Question About HMC-150
    Posted by Dave George on July 12, 2011 at 1:33 pm
    I’m trying to use my HMC-150 to stream video over the Web, and I’m told I need an AV/DV converter. I’m a little confused as to why I’d need to convert to digital video. Isn’t the HMC-150 already recording digital video? Can someone straighten me out here? Thanks!
    Dave George
    Director, Social Media
    Mark Dail replied 13 years, 2 months ago 3 Members · 3 Replies
  • Guy Mcloughlin
    July 12, 2011 at 8:56 pm
    The HMC-150 records HD video in digital format to it’s memory card.
    The video that comes out of the HMC-150 AV port is analog, and thus needs to be digitized to use it for video streaming.
    The video that comes out of the HMC-150 HDMI port is digital, but then you need a HDMI digital input port on your computer to use the HDMI video feed, and you will likely have to down-scale the HDMI HD image down to SD before it can be used for video streaming.
    I looked in to this before and thought that I would buy a used DVX-100 camera for it’s SD Firewire port so that I could stream high quality SD video to the web.
  • Dave George
    July 13, 2011 at 1:29 pm
    Guy, thanks so much for the thoughtful response. That makes total sense to me now. My goal is also to webstream, so I ran the signal through an AV/DV converter (it arrived yesterday, coincidentally) and it’s working very well. (To my utter shock.) (Technical things never work right away for me.) https://www.ustream.tv/channel/it-s-the-booze-talking
    Anyway, thanks for taking the time to respond.
    Dave
    Dave George
  • Mark Dail
    July 8, 2013 at 6:09 pm
    Do you have to come out of the HDMI port to record the audio/video output into a computer?
    So the 2.0 USB will or will not work?
    Will any out put need to be downsizes to SD to go into straming/recording on a comuter?
    Mark
