Activity Forums Apple Final Cut Pro Legacy Basic question about dissolves etc
  • Basic question about dissolves etc
    Posted by Bob Flood on January 13, 2006 at 3:13 pm
    Hey
    a basic question for a basic forum:
    what am i missing that i cannot cut a clip into a sequence when i have a dissolve or other transtions at the head or tail of the shot i want to overwrite?
    i am used to a system where if i do an overwrite where transitions live, the transision just goes away, and you have to put it back.
    With FCP 5.0.4, i keep getting an erro message saying something like “By Doing This a transition will be split so i cant do it”
    is there not a way to overwrite a clip with a transition on the head or tail or both, and just have it either stay or go away?
    thanx
    bee eph
    Bob Flood replied 20 years, 8 months ago 3 Members · 3 Replies
  • David Battistella
    January 13, 2006 at 3:21 pm
    What if you select teh clip and use replace.
    Or
    Maybe you can use “overwrite with transition” if you drag the clip over the canvas window.
    David
  • Todd Perchert
    January 13, 2006 at 3:46 pm
    Yep. The replace edit function may be your best bet. It works well without in/out points and just using the position indicator on the timeline and your clip.
    TC
  • Bob Flood
    January 13, 2006 at 7:22 pm
    Thanx guys
    i will give it a try!
    bee eph
