Activity › Forums › Apple Final Cut Pro Legacy › Basic Page Peel question
Posted by Mark Palmos on January 28, 2008 at 11:29 amHello all,
The FCP page peel (turn) does not seem to work with text… not the basic static text generated by FCP or text generated by a motion project. It just cuts on. Double clicking the transition on the timeilne brings up the controls but adjusting them makes no difference.
Ive tried turning from a transparent slug to text but this does not work either.
Any luck anyone or is this some uber-crap legacy effect to be ignored?
tx
Mark.Mark Palmos replied 18 years, 8 months ago 4 Members · 9 Replies -
Andy Mees
January 28, 2008 at 12:43 pmit works just fine here with FCP generated text Mark,
you might want to check your transition settings, particularly the direction -
Walter Biscardi
January 28, 2008 at 12:59 pm[Andy Mees] “it works just fine here with FCP generated text Mark,”
yep, just tried it here too, works as expected.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Mark Palmos
January 28, 2008 at 1:28 pmHi Walter and Andy,
Are you guys trying this with text on a transparent background over a second video track?
The page turn works fine with two pieces of video, but when I put the basic FCP text “SAMPLE TEXT” on a V2 above some other video clip on V1, and want to add a transition to page this text on and over the V1 track below, it just cuts on… no paramter changes in the Viewer make any difference.
If I park the CTI over the mid point in the transition and move the “direction”, the full “SAMPLE TEXT” is there all the time… no effect at all.
And with you?
ta
Mark -
Tom Wolsky
January 28, 2008 at 2:08 pmWorks for me. Sounds like you haven’t applied the transition correctly. Check it’s duration and make sure it hasn’t been applied as one frame.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop” -
Mark Palmos
January 28, 2008 at 2:26 pmmaybe its a PAL/NTSC thing?
I will try an NTSC project later.the duration is anywhere between 1 second and 2 seconds, there are not that many paramters to change and it works using the default parameters when page turning regular video clips, but not when using anything with an alpha channel.
Interstingly it works at the tail of a clip but not at the head. If I alt-drag the very same effect to the head of the same clip, it does not work, but works fine at the tail.
Mark.
Tom Wolsky
January 28, 2008 at 2:33 pmI missed that you were peeling it on. Clip the reverse arrow to bring it on.
All the best,
Tom
Mark Palmos
January 28, 2008 at 2:41 pmOMG
i have got to wear glasses while editing obviously, that reverse icon looked like a speck of dust on the 1920×1200 monitor!yep, it now works fine, thank you all.
till later
Mark. -
Andy Mees
January 28, 2008 at 3:31 pmoh for goodness sakes Mark, didn’t I tell you to check the direction in my first reply 😉
Mark Palmos
January 28, 2008 at 3:39 pm[Andy Mees] ”
oh for goodness sakes Mark, didn’t I tell you to check the direction in my first reply ;-)”LOL
yep, and i was dragging the Start and End sliders the oppoiste way round thinking thats what you meant.and after all that ive convinced the client to go for some sexier text move anyway!
at least i will put on my glasses before posting next time.
thanks mate
mark.
