Activity Forums Apple Final Cut Pro Legacy Basic Motion and Transitions
  • Basic Motion and Transitions
    Posted by Morris Barrier on April 24, 2005 at 7:53 pm
    From time to time when I am making a photo montage I encounter this problem. For effect I scale and rotate an image but once I add the cross dissolve the basic motion does not change with the new handles. Sometimes it does, other times it doesn’t. Other than going into each clip and moving my keyframe to compensate for the longer handle, is there a shortcut so my transitions won’t look so choppy?
    Here’s another little problem. I placed livetype textures behind my photos shot portrait style. And man these zebra looking squigglies are all over the picture. For a test fix I copied the photo and pasted it into another layer so the photos are doubled on top of one another and it fixes it but there has to be a better way. I’ve never had this problem with full motion video and not all photos have this problem.
    Thanks.
    Steve Eisen replied 21 years, 4 months ago 4 Members · 3 Replies
  • Uwe Klimmeck
    April 24, 2005 at 9:04 pm
    I don’t use dissolves that exceed the clip-length anymore (centered or ending at cut).
    Keyframes are buggy if you put a dissolve on top. Same for slowmotion / variable speed.
    If you use dissolves that start on cut at the beginning and end on cut at the end of a clip it works okay.
    Greetings
    Uwe
  • Kevin Monahan
    April 24, 2005 at 9:32 pm
    I usually drag the keyframes past the handle area of the transition, so that as the images blend, the motion effects are still in motion, and in doing so, don’t halt before the transition is complete.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Steve Eisen
    April 25, 2005 at 3:56 am
    Morris,
    A little hint, drag your motion tab into your timeline.
    G5 Dual 2.5 160GB System 400GB Media Drive ATI 9800 256MB 6 GB RAM
    Dual Gig Quicksilver 1GB RAM 80 GB System drive (3) 250 GB internal media storage
    15″ Al Powerbook 1.25 1GB RAM
    OS 10.3.8 FCP 4.5, DVDSP 2, QT 6.5, Boris Red 3GL 1.65 TB External Stor
