Basic Masking Can do Some Amazing things
I would like do do the shapes and graphs that are being done in this video. If I design the finish graphs in Illustrator and then import them into separate pieces, how do I mask them out. I.E. where it looks like a square in the center of the page is sliding in from nowhere. I know you would have the square sitting in place, and then put a mask over it and animate the position of the mask so that the square or whatever would appear. How do i create a mask over that that can be animated?
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
