Activity › Forums › Adobe After Effects › basic light question
Posted by Florian Herweg on May 30, 2007 at 9:26 pmhey there!
i’m a bit confused now … do lights (point or spot) illuminate through layers? if yes … is there work around that prob?
thanks a lot!
best
flowKevin Camp replied 19 years, 3 months ago 5 Members · 12 Replies -
Lord Scales
May 30, 2007 at 9:29 pmGo in Transform > Material Options > Light Transmission, if I am not mistaken, so you can set how much the light will pass through it.
Florian Herweg
May 30, 2007 at 9:37 pmlight transmission is set to 0% … still the light is coming through and illuminates all layers behind it …
even if i set everything to 100% nothing happens … really confused now!
Steve76
May 31, 2007 at 8:15 pmIs the Layer that is letting all the light through by any chance a 2D Layer? I think lights only interact when you tick the 3D switch.
Cheers,
Steve
Florian Herweg
May 31, 2007 at 8:29 pmyes … it is a 3d layer … and shadows are activated (both on the light and layers) but still its shining through 🙁
Kevin Camp
May 31, 2007 at 8:38 pmhow about the layers that are receiving the light that is passing through the other layers, are they 3d also?
Kevin Camp
Designer – KCPQ, KMYQ & KRCW -
Kevin Camp
May 31, 2007 at 8:44 pmactually not just 3d but also have accept shadows ‘on’
Kevin Camp
Florian Herweg
May 31, 2007 at 9:08 pmyes … everything is checked … all layers are 3d layers and accept shadows is turned on …
try it out by yourself guys … put 3 layers along the z axis (with space between them of course) and put a spotlight with small cone angle in front of the first one so that it just hits the middle of layer … the light illuminates all 3 layers …
if you activate the shadows the illumination becomes darker … but the light is still shining through …
Kevin Camp
May 31, 2007 at 9:14 pmyeah, i’ve done it, and it worked fine. the back layer and the front most layer were completely black, only the middle layer showed a spotlight. that’s why i was trying to help you troubleshoot your problem.
Kevin Camp
Florian Herweg
May 31, 2007 at 9:20 pmmhhh … thats strange … could you do me the favor and post the ae file … that would be great!
