Activity Forums Adobe Illustrator Basic Ilustrator question regarding paths
  • Basic Ilustrator question regarding paths
    Posted by Zach Blumstein on April 19, 2009 at 6:07 pm
    hi im sure someone else has covered this before
    but im wondering how do i take an image and make it follow
    a path i created, kinda like path text only with images instead of text.
    thanks
    Vincent Rosati replied 17 years, 4 months ago 2 Members · 3 Replies
  • Vincent Rosati
    April 21, 2009 at 9:12 pm
    Hmmm. I’m not sure I understand. You want’ to have a raster image animate along a path?
    or
    Create a pattern brush of an image, than apply the brush to a path?
    If the latter, you could open the image with Illustrator, than drag it into the brush palette.
    Than, select the path and click on the brush you just created, in the Brushes palette.
    Let us know if this is even remotely close to what you are looking for.
    Vince
  • Zach Blumstein
    April 25, 2009 at 6:43 pm
    sorry i will try to explain better
    say i want to take a star and have it follow a circle path
    how would i do that? can it be done using a raster image
    or is a brush better?
  • Vincent Rosati
    April 29, 2009 at 5:19 pm
    I don’t think you can use a raster as a brush, unsure.
    Here’s a file that describes how to make a Pattern Brush…
    https://www.newinelabs.com/rosati/tutorials/spirals_redux_cs2.ai
    You can apply a brush to any path.
    Vince
