Activity Forums Apple Final Cut Pro Legacy Basic HD Question
  • Basic HD Question
    Posted by Neal Klaeser on October 26, 2011 at 4:55 pm
    I shot some footage on my HPX170 at 720p/30pn and brought it into FCP. I opened a new project and decided to drag my footage onto my timeline and it prompted me to change the settings of the timeline to match the footage settings. OK, I did. I go to settings and it tells me the frame size is 960×720.
    I thought it would read 1280×720? So I go to the pull down menu next to the frame size tab and there is a setting for HDTV 720p (16:9) and there is a tab that reads HD720 (960×720) 16:9.
    Neal Klaeser
    Real to Reel Productions
    http://www.realvideopro.com
    Bret Williams replied 14 years, 11 months ago 5 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    October 26, 2011 at 5:06 pm
    DVCPRO HD is an anamorphic format. Meaning squeezed. So instead of full raster 1280×720 it is 960×720. Editing apps stretch it back out to full screen.
    Shane
  • Neal Klaeser
    October 26, 2011 at 5:11 pm
    If I am having someone create moving graphics or still images for this project should I tell them 960×720? Because that is the aspect ratio for this project?
    Neal Klaeser
  • Alan Okey
    October 26, 2011 at 5:12 pm
    DCVPRO HD is not a full-raster HD format. It squeezes the image and records a 4:3 960×720 image with anamorphic pixels for 720p (or 1280×1080 for 1080i/p), then stretches the image back out to a 16:9 ratio on playback. This is done to reduce the bandwidth necessary to record the signal.
    Other formats such as XDCAM EX or AVC-Intra record a full-raster 1280×720 or 1920×1080 square pixel image.
  • David Dubé
    October 26, 2011 at 7:47 pm
    I would create my graphics in 1280×720 square pixels, someone please correct me if I’m wrong.
  • Shane Ross
    October 26, 2011 at 7:49 pm
    I concur. Have them made 1280×720 full raster
    Shane
  • Neal Klaeser
    October 26, 2011 at 7:55 pm
    Thank you for all the information.
    Neal Klaeser
  • Bret Williams
    October 27, 2011 at 4:54 pm
    Don’t edit in a 960×720 sequence though. Otherwise you’re completely losing the point of the 1280×720 graphics. Graphics made in DVCProHD (or placed in a DVCProHD sequence) will have noticeable stair stepping nothings like angled lines and curved letters. Especially in 720 vs 1080. You want to work in a 1280×720 Pro Res sequence. You might want to work in a 1920×1080 sequence in your graphics are a more substantial part of your show.
