Activity › Forums › Adobe After Effects › Basic Export in AE CS3 gets stretched horizontally
Posted by Jojo Galan on June 6, 2010 at 6:39 pmHello,
Newbie here. HELP!
I have a panasonic dvx100b camera and am shooting Standard Definition 720 x 480. When I put a file in a DV Composition in After Effects CS3 and then export with no effects, my video is still 4:3 but it’s stretched. Can someone please help?
Thank You.
jojoSteve Roberts replied 16 years, 3 months ago 3 Members · 9 Replies -
Steve Roberts
June 6, 2010 at 8:30 pmIt appears stretched in the computer. It would not be stretched on a TV. If you just want to play back on a computer, use a square-pixel comp preset.
Look up “non-square pixels” and “pixel aspect ratio” in the help.
Shahin Ghahremani
June 6, 2010 at 8:49 pmHi Jojo,
OK, I think you set the footage aspect ratio to 4:3 but is the Pixel Aspect Ratio also set to SQUARE PIXEL or it is set to something else?
The footage ratio can be chosen or set on the format presets box from the export format settings, I think you should set it to NTSC DV 720×480, but make sure the pixel aspect ratio is also set to D1/DV NTSC (0.91) or if it didn’t work set it to SQUARE PIXEL!
Hope this can help you.
Good luck.Shahin
P.S. If you couldn’t get the right result from the advice above, please provide some more information about the original footage ratio and pixel ratio and also your composition settings in reply! thank you.
Jojo Galan
June 7, 2010 at 3:08 amAccording to After effects The video has specs of:
720×480 (0.91) separating (lower)
23.976 fps 3:2 removal (https://WWWSW) – 24p AdvanceWhat is the best timeline/composition to edit in?
I am currently using a DV Timeline 720 x 480 – 3:2The 24P advanced video is at 0.91 but it seems like I have to use a square pixel aspect ration on the timeline for the video to look right. Is this correct?
Also, should I have the timeline at 23.976 or 29.97?
Pros and cons of either?Why does the original video with an aspect ratio of 0.91 look fine, but when I export, it HAS to be 1.0 square pixel to look right on my computer monitor and HDMI TV?
Thank you for the help.
Jojo Galan
June 7, 2010 at 3:10 amCan a non-square 0.91 and a square 1.0 video be in the same composition timeline?
Pros and cons of either?The output video seems to have interlace lines as well.
I tried a lot of different settings, read the dvx100 book by barry, and also read my manual for after effects, but still am a bit lost.
Please advise.Thank You DVXuser community. You rock!
Steve Roberts
June 7, 2010 at 4:28 pm“Thank you DVXuser community”?
Busted for a cross-post! Bad internet etiquette to cross-post!
Jojo Galan
June 7, 2010 at 5:04 pmI am sorry.
DVX didn’t respond so I posted here.
Thanks for the help.I am using square pixel on export in After Effects. When I bring that square pixel video (1.0) into the original DV project (0.9) in premiere pro will it be fully compatible?
Thanks again!
Creative Cow is great!
Steve Roberts
June 7, 2010 at 5:45 pmYes. You should not use DV square pixel when going back to Premiere or any other video editing app, in general.
Just use one of the presets Dave mentioned.
Jojo Galan
June 7, 2010 at 11:47 pmThanks Steve and Dave for having patience and taking time to help a newbie like me out.
I learned ALOT from this thread and now got it worked out lovely. I’ll be editing tonight and tomorrow.
Is it bad etiquette to post a link to the video here when it’s done? I thought it would be appropriate because I never would have been able to do it without your help.
You guys are co-producers.
Thanks buddies,
jojo -
Steve Roberts
June 8, 2010 at 2:04 pmNot bad etiquette. It’s quite all right.
… depending on the video, of course. 🙂
