Activity Forums Compression Techniques basic compression : motion presentation to 800×600 LCD
  • basic compression : motion presentation to 800×600 LCD
    Posted by Alex Jones on September 16, 2008 at 11:10 pm
    Hi, total newbie to video,so any help will be much appreciated, so..
    I’m building a presentation in motion 3, basic 800×600 presentation and output is to a crappy 800×600 LCD picture frame. It needs to be MPEG as this is the only motion video that the frame can play.
    I need to figure out the best compression rate as I’m trying to compress with Mpeg-1 and it comes out looking terrible, is it because it is scaling down? The picture is totally blurry and the words are unreadable?
    Anyway, would love some help as really enjoying the video experience so far.
    thanks,
    Alex.
    Daniel Low replied 17 years, 12 months ago 2 Members · 9 Replies
  • 9 Replies
  • Daniel Low
    September 17, 2008 at 7:41 am
    If you have to use MPEG, use MPEG-2 or MPEG4 (H.264) rather than the ancient MPEG-1.
    What compression tools do you have?
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Daniel Low
    September 17, 2008 at 1:35 pm
    Sorry – I should have asked what types of MPEG does the picture frame support?
    Do you have a link to a product spec page for it?
  • Alex Jones
    September 17, 2008 at 5:13 pm
    Hi Danny,
    yeah, I’m going to try mpeg4 again, it’s one of these cheap $150 no name LCD Frames, the specs are really helpful saying multi-media formats supported are MP3/JPEG/JPG/DIGITAL VIDEO!
    I can get mpeg1 to work so I’ll give the others a try and get back in here.
    thanks,
    A.
  • Alex Jones
    September 17, 2008 at 5:35 pm
    okay, so compressed to mp4 and it works on the LCD! I checked it in the split preview on my machine and it looks great, but again on the frame it looks terrible. I think the LCD just can’t handle the graphics?
    A.
  • Daniel Low
    September 17, 2008 at 7:55 pm
    What settings (frame size and datarate) are you using?
  • Alex Jones
    September 17, 2008 at 8:49 pm
    the actual frame has a res of 800×600. here’s how I compressed. And now, the frame isn’t even playing the mp4?! Totally duff frame I think!
    Description: MPEG-4 video with AAC audio at 48 kHz. Settings based off the source resolution and frame-rate.
    File Extension: mp4
    Estimated file size: 4.76 MB
    Audio Encoder
    Format: MPEG4
    Sample Rate: 44.100kHz
    Channels: 2
    Bits Per Sample: 16
    AAC encoder quality: high
    Data rate: 64 Kbps
    Video Encoder
    Format: MPEG4
    Width: (100% of source)
    Height: (100% of source)
    Selected: 800 x 600
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: 29.97
    Frame Controls: Automatically selected: Off
    ISMA Profile: 0
    Variable bit rate, medium quality
    Hinted for streaming server with
    packet size: 1450 bytes
    and packet duration: 100 milliseconds
    Allow Podcasting information: Off
  • Daniel Low
    September 17, 2008 at 10:20 pm
    Set the frame size of your encode to 640×480
    Turn off ‘Hinted for streaming server’
    That might help.
    You’ve still not said what software you are using to do this compression with?
  • Alex Jones
    September 17, 2008 at 10:23 pm
    I’ll give it a try. Oh, and using Compressor 3.
    thanks for all your help!
    A.
  • Daniel Low
    September 17, 2008 at 10:40 pm
    You also need to set an explicit datarate say 1500Kbits/ rather than just ‘Medium Quality’
    Don’t forget to deinterlace if your source material is interlaced.
    It’s also worth upping the contrast a bit for picture frame devices
