Activity Forums VEGAS Pro Basic Color Correction Question
  • Basic Color Correction Question
    Posted by Steven Quan on December 6, 2011 at 9:35 am
    Just learning color correction using Vegas 9 Pro. Experimenting with Color Correction, clicked on “Reset to None”. There are total of 6 empty droppers which I believe you are supposed to click on and then point to a corresponding color in the video to color correct. Why are there 6? Why are there two droppers for every circle? Am I supposed to click on both droppers and do color correction for each?
    John Rofrano replied 14 years, 9 months ago 2 Members · 1 Reply
  • John Rofrano
    December 6, 2011 at 1:49 pm
    [Steven Quan] “Why are there two droppers for every circle? “
    One is the Complimentary Color (-) and the other is the Adjustment Color (+). The Complimentary Color will select the color that is opposite the color you are choosing with the eye dropper. The Adjustment Color will select the same color on the color wheel that you are choosing with the eye dropper.
    [Steven Quan] “Am I supposed to click on both droppers and do color correction for each?”
    No. For color correcting (i.e., making a correction to the color you select) you want to only use the Complimentary Color eye droppers. For High you want to select a color that should be white. For Mid you want to select a color that should be gray. For Low you want to select a color that should be black. Usually finding white and black is fairly easy but there may be no gray in your image so you need to choose a color that, if the image was converted to black & white, should look gray.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
