Activity Forums Adobe Premiere Pro Basic audio sync workflow question for Premiere
  • Basic audio sync workflow question for Premiere
    Posted by Dale Holman wallace on October 19, 2015 at 4:26 pm
    Hi there,
    I’m looking for the simplest, most efficient workflow for syncing audio to proxy files in Premiere Pro, with regards then being able to easily re link to then raw files.
    If I merge the rushes and audio, I am concerned the file name that is created will be different to the raw file, therefore making relinking problematic. However, it would be useful to link the files so that I can dump them in a bin and go through and find the files I need like that, rather than simply have a timeline of footage with audio synced in the timeline alone, if that makes sense.
    Dale
    Andrew Kimery replied 10 years, 11 months ago 2 Members · 1 Reply
  • Andrew Kimery
    October 19, 2015 at 7:05 pm
    You can create a single camera multicam clip (which is basically just a nested sequence).
