Activity › Forums › Apple Final Cut Pro Legacy › Basic audio sweetening in FCP 7
  • Basic audio sweetening in FCP 7
    Posted by Olivier Prudhomme on December 8, 2013 at 10:43 pm
    I am working on a project:
    :45 spots, talking heads,
    very good recorded sound/dial
    a couple woosh sfx
    ambiance music track I added in BG
    I don’t have the budget to send to a pro audio guy so I am hoping to do my own audio sweetening.
    So far I applied the normalization on the clips… and made sure the overall level of the spot is around -12db.
    How do I create this rich sound you get when a spot comes back from mixing?
    Thx
    Olivier Prudhomme replied 12 years, 9 months ago 4 Members · 6 Replies
  • John Fishback
    December 9, 2013 at 5:15 pm
    There are many ways an audio pro enhances a track. Basic tools are EQ and compression. although, there are many more. There’s no preset formula. Google for tutorials on mixing. You will find good info.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
  • Olivier Prudhomme
    December 11, 2013 at 2:07 am
    googled …. nothing really serious / interesting comes up as far as sweetening.
    “mixing” is getting the levels correct but I want to sweetened so it all sounds loud/rich w/o spiking
  • Tom Matthies
    December 11, 2013 at 6:56 pm
    Try the compressor/limiter filter and play with the settings until you get the result you’re looking for.
    E=MC2+/-2db
  • Olivier Prudhomme
    December 11, 2013 at 7:00 pm
    thx for the tip.
    Been doing that and quite happy with the results actually
  • Sascha Engel
    December 18, 2013 at 6:24 am
    If you know how to work with Soundtrack Pro, which allows you to use VST Plugs,
    Then get Ozone and WAVE, with this you can do a great audio finalisation.
    Special the compressors and limiters of WAVE are incredible.
    Greetings,
    Sascha Engel
    TIME BANDITZ Productions
    http://www.youtube.com/taikang
  • Olivier Prudhomme
    December 18, 2013 at 5:49 pm
    thx, I’ll check it out
