Activity › Forums › Adobe After Effects › Basic animation prob
  • Basic animation prob
    Posted by Bob Burwell on May 1, 2010 at 9:42 am
    A real elementary problem here, animating a ball! The small ball is at left side of screen. Hit the stopwatch in position property (k/f 1), move marker to 1 sec, move ball to centre screen (k/f 2)
    No problem so far but now I want to scale the ball to fill the screen. Moved marker forward 1 sec. Hit scale stopwatch, scaled the ball up. (k/f 3). But the ball is now scaled up from k/f 1. Why is
    that?
    Erik Waluska replied 16 years, 5 months ago 2 Members · 5 Replies
  • Erik Waluska
    May 1, 2010 at 7:07 pm
    Because you only have one keyframe set so there’s no animation. You have to set a keyframe for the starting scale value, then move a second or however far down the timeline and set a second keyframe with a different scale value.
    -E
  • Bob Burwell
    May 2, 2010 at 8:32 am
    Thanks for that but I did have a k/f set at the start. i.e zero. Then I moved along setting 2 more. One with position moved and the other with scaling UP. So why is it then showing scaled UP at the start?
  • Erik Waluska
    May 2, 2010 at 5:13 pm
    So you have set two scale keyframes, right? The only way it would remain scaled up and not animate is if you only have one scale keyframe, or if all of the scale keyframes have the same value. So what are the scale values at each scale keyframe?
    -E
  • Bob Burwell
    May 3, 2010 at 3:44 pm
    Hi Erik. I got it working right now. Maybe missed a scale k/f. Thanks for your help!
  • Erik Waluska
    May 3, 2010 at 4:29 pm
    No problem. Glad you got it figured out. Thanks for letting me know.
    -E
