Activity Forums Panasonic Cameras Bare Minimum Config for Interviews
  • Bare Minimum Config for Interviews
    Posted by Matthew Ingram on December 4, 2006 at 6:18 pm
    Newbie questions sorry….
    Should I:
    a) Simultaneoulsy mount a shotgun on the shoe of my DVX *and* record with a lav?
    b ) Is it possible to both hold a shotgun mike and film with the camera at the same time and forget the lav? (‘fraid I don’t have a boom op!)
    I’m doing informal interviews with musicians. I’d like to keep things as simple as possible.
    Noah Kadner replied 19 years, 9 months ago 4 Members · 5 Replies
  • Frosch
    December 4, 2006 at 7:15 pm
    Do you have access to a c-stand? Your best bet would be to mount the shotgun above your interviewees as close as you can w/o busting frame.
    As for your option “b”, you could always juggle the mike & camera duties, but that sounds like a recipe for disaster. Better off mounting it to your camera, or back to my first idea.
  • Matthew Ingram
    December 4, 2006 at 8:39 pm
    thanks for your input frosch
    @ c-stand: i was hoping to maybe not have them nailed to their seats :-/
    @ juggling duties: what you mean putting the camera on the tripod and then the mic on a stand? (i’m inferring that one can’t hold a shotgun *and* point the camera feasibly)
    i think i may have to try a lav/shotgun-mic-mounted on camera combo.
    do you happen to know if a sennheiser me66 will protrude in front of the camera if mounted on top?
  • Tom Maloney
    December 5, 2006 at 2:29 am
    Try your setup before you go out with it and you will see the problems of placing the shotgun on camera. Even a shotgun should be placed as close to talents mouth as possible. And a shotgun might not be the best possible choice for shooting interiors, too much reflections off hard surfaces
    good luck
    Tom
  • Matthew Ingram
    December 5, 2006 at 5:11 am
    thanks tom.
    next question then!
    can you reccommend a directional mic i could mount on the camera to double up with a lav?
  • Noah Kadner
    December 9, 2006 at 4:37 pm
    IMO a directional mic on the camera is fairly worthless. Much better with the c-stand approach. Or if you don’t want to be nailed down, hire someone to boom. Without good sound it’s kind of a pointless exercise anyway.
    -Noah
    Noah’s DVX100 and FCP DVD:
    http://www.callboxlive.com
