Activity › Forums › Adobe Illustrator › Bar Graph on Circle Path – Illustrator
  • Kalleheikki Kannisto
    February 19, 2016 at 12:18 pm
    One solution:
  • Hunter Hanson
    February 19, 2016 at 4:38 pm
    This is a pretty good solution. However in the event I have uneven data sets, which I do, I assume there will be one open piece of the arc. Additionally I have over 200 data sets and they are upwards of 300 million in value at any given point.
    February 19, 2016 at 5:24 pm
    I tested your art-brush-on-a-circle method and it actually looks significantly better than the arc warp (looks like the arc warp isn’t really properly circular).
    Here’s the same graph with art brush (including the gap: I drew a white rectangle in the background before creating the brush).
    You said you were getting a distortion at the top. Can you show an example of the problem?
