Activity Forums Adobe After Effects banding/tearing in pre-composed and collapsed layers.
  • banding/tearing in pre-composed and collapsed layers.
    Posted by Mike Roberts on August 17, 2010 at 11:50 pm
    hey guys,
    I’ve got a ton of solids making a 3D shape, which is pre-composed and collapsed in the top layer so I can treat it like it’s own 3D model. I’m getting a ton of banding and weird shearing… anyone know what’s up?
    Mike Roberts replied 16 years ago 2 Members · 4 Replies
  • Chris Wright
    August 18, 2010 at 12:20 am
    hmmm. I know Alpha Add is supposed to fix visible edges. Plus a little interlace flicker blur effect too. and banding is color so try 16bpc in your project.
    https://help.adobe.com/en_US/AfterEffects/9.0/WSFB0FE760-71F3-4616-AE88-275D718E7125a.html
    https://technicolorsoftware.hostzi.com/
  • Mike Roberts
    August 18, 2010 at 1:01 am
    Thanks Chris,
    I saw the alpha add on another post, but couldn’t get it to work. I had great luck with this kind of stuff in CS4 (about the only thing I had great luck with in CS4) but maybe CS5 forgot to play nice with pre-composing. In CS4 sometimes you’d get this effect with DOF switched on…
    what a pain. And here was me telling a client they I could do the whole job in AE and save them some money…
    Here’s a screen grab
  • Chris Wright
    August 18, 2010 at 1:20 am
    its entirely possible that you have alpha issues. use alpha levels with both rgb to set full b/w and alpha to full white. I’ve had to use that plugin before to create mattes.
  • Mike Roberts
    August 18, 2010 at 1:31 am
    Hey Chris,
    thanks for helping with this…
    not sure what you mean… I’m sorry, i could just be blanking.
    I am using masks to make those shapes on layers from illustrator.
    Which plugin do you mean?
