Activity › Forums › Adobe After Effects › Banding/Moire on SD DVCAM
  • Banding/Moire on SD DVCAM
    Posted by Michael Dominic on October 13, 2017 at 1:51 pm
    Hello,
    These stills are from a documentary called Sunshine Hotel that I made back in 1999/2000 on DVCAM.
    It’s having a new success on Amazon Prime and I am in the process of finishing remastering, re-color correcting and up-ressing it. I have recut the entire film in Premiere and then did the color correct in After Effects.
    As you can see these areas of banding are terrible. They are like this on the master tapes. When playing they shimmy like crazy.
    These and others spots have been a thorn in my side for nearly 20 years.
    I would like any real solutions.
    Thanks.
    Michael Dominic replied 8 years, 11 months ago 1 Member · 6 Replies
  • Michael Dominic
    October 13, 2017 at 4:33 pm
    DV is like working with wet paper.
    It’s no the up-rezz that’s causing it. It was alway there.
  • Michael Dominic
    October 13, 2017 at 5:26 pm
    I haven’t tried field orders. Premiere makes everything progressive, but it might be worth a shot. The footage looks good, but the blown out area are shit.
  • Michael Dominic
    October 13, 2017 at 6:24 pm
    Its 29.97.
    The film had it’s day. It ran on Sundance Channel 2002-2004 like this and no one ever complained. I just figured if I am remastering I might as well fix this along with other things I fixed, if I can.
  • Michael Dominic
    October 15, 2017 at 12:32 pm
    So Dave, this is my “fix”. I’m hoping that you (or other can improve upon it.
    If I just set “Separate Fields” to OFF that mostly fixes my main strobing issue, but then the rest of the clip looks interlaced.
    So what I am doing is in the project window I duplicate the video and then separate fields. Then in the comp I duplicate the clip. I replace it with the new video. THEN I mask of the problem area so just those show over the original clip.
    There has to be a better way.
  • Michael Dominic
    October 15, 2017 at 1:32 pm
    Actually that can make it look bad in another way.
  • Michael Dominic
    October 18, 2017 at 4:09 pm
    I wrote above that these were shot at 29.97.
    I’m remastering so that means that I’ve recut from the masters in Premier.
