Activity Forums Adobe After Effects banding on mask/vignette
  • banding on mask/vignette
    Posted by Xtothed on April 12, 2006 at 2:32 pm
    hi guys,
    have animated some still images and added lens flare across them – nothing special or taxing.
    on top of this i have added a black solid, with a mask, feathered to 100, and 33% opacity.
    It looks fine in AE6.5 but when i render it out, either uncompressed or otherwise, then import it into FCP, to dump to tape the mask/vignette has banding through it…it isnt nice and even/smooth.
    I have checked the best quality and rasterise buttons, obviously?!
    Xavier
    Xtothed replied 20 years, 5 months ago 2 Members · 2 Replies
  • Harryjf
    April 12, 2006 at 5:46 pm
    Can you work in a 16 bits per channel project?
    Go to File>Project Settings>Color Depth and change it to 16.
    If that doesn’t work, try dithering your comp a little bit.
    Add an adjustment layer on the top of your comp, and add the filter Noise & Grain>Noise. Try as much as 5% noise, don’t use color noise. This might tone down the banding problem a little.
  • Xtothed
    April 13, 2006 at 9:35 am
    cheers
    that worked brilliantly
