Activity › Forums › Adobe Premiere Pro › Banding in the sky only after I render a clip
  • Banding in the sky only after I render a clip
    Posted by Luke Pearson on October 31, 2016 at 9:19 pm
    I have an opening scene in a video I’m working on that starts with a slow fade in. That first clip looks crisp and smooth until I render the clip. Then you can see terrible banding in the sky during the fade. It’s also there after export.
    The footage was shot on an FS7. thanks for any help!
    Jacobi Alvarez replied 8 years, 3 months ago 9 Members · 30 Replies
  • 30 Replies
  • Duke Sweden
    November 1, 2016 at 12:33 am
    By “rendering” do you mean rendering the timeline to play back smoother, or encoding the clip with Media Encoder, for example? If you’re encoding what codec are you using?
    Also, you can eliminate most of the banding by adding like 3-5% film grain to your footage.
  • Alan Lloyd
    November 1, 2016 at 12:36 am
    That sort of banding is usually the result of significant bitrate reduction.
    It’s not just the codec, it’s the data rate.
    And yes, adding just a touch of noise might help smooth things back out, just don’t step on it too hard in the encoding/output!
  • Luke Pearson
    November 1, 2016 at 12:43 am
    thanks for the quick reply. by “rendering” I mean in the timeline for smoother playback. as in, changing the render bar from yellow to green. When the render bar is yellow there is no banding and the dissolve is smooth and clean. as soon as I render it or export it, the banding is present.
    I’ve exported to different codecs with no luck too. I’ve tried the grain too with no luck.
  • Luke Pearson
    November 1, 2016 at 12:44 am
    thanks for the help. There is already noise added to the clip which isn’t helping. Is there anything else I can do to stop the bitrate reduction?
  • Luke Pearson
    November 1, 2016 at 12:50 am
    here is a before/after render picture:
  • Luke Pearson
    November 1, 2016 at 12:53 am
    they kind of look the same after exporting and uploading jpegs but in the timeline they look night and day different. One is smooth and the other has noticeable banding in the sky
  • Duke Sweden
    November 1, 2016 at 1:18 am
    From Adobe:
    Video Rendering settings
    Video Rendering settings control the picture quality, compression settings, and color depth that Premiere Elements uses when you play video from the Expert view timeline.
    To access Video Rendering settings, choose Edit > Project Settings > Video Render. These settings include the following options:
    Maximum Bit Depth
    Allows Premiere Elements to use up to 32‑bit processing, even if the project uses a lower bit depth. Selecting this option increases precision but decreases performance.
    File Format
    Specifies the format of the preview video.
    Compressor
    Identifies the codec (compressor/decompressor) that Premiere Elements applies to generate movie previews. The project preset defines the codec. You cannot change it because it must conform to the DV standard.
  • Alan Lloyd
    November 1, 2016 at 1:29 am
    Another issue I can see is that with the images as dark as they are there is very little dynamic range available for depiction of any gradient in the sky. While I’m sure it’s called for in the narrative you’re really limiting yourself into a corner with how little of the available palette that’s being used in those images.
  • Alan Lloyd
    November 1, 2016 at 1:32 am
    Another thought, in the form of a question: What are you outputting and what are your settings? (File type, resolution, data rate, etc.)
  • Luke Pearson
    November 1, 2016 at 1:34 am
    sorry! forgot to mention the images i posted are midway through the fade up. thats why they’re dark. Thats the only place the banding is occurring so thats why I posted those.
Page 1 of 3
