Activity Forums Adobe After Effects Banding in lighting
  • Banding in lighting
    Posted by Aaron Beall on May 13, 2011 at 7:26 am
    I’ve created a simple composition that uses a 3d solid layer and a point light to create a soft vignette appearance. Everything looks okay when exported to lossless QuickTime, but when I sent it to the video guy he said that after compressing there was bad banding, and I had to remove the light completely (everything looks flat and boring now.)
    Is there a trick in AfterEffects to create soft lighting with minimal compression banding?
    Dave Johnson replied 15 years, 4 months ago 3 Members · 2 Replies
  • Tudor “ted” jelescu
    May 13, 2011 at 11:18 am
    Work in 16 or 32 bit and render a sequence of files tga @ 32bit or uncompressed tiff.
    Sometimes it helps to add grain.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Dave Johnson
    May 13, 2011 at 1:02 pm
    Search the AE forum for “banding” and you’ll find tons of threads with tips … most of which center around upping the color resolution, adding grain and/or adjusting individual color channels.
