Activity Forums Zaxwerks banding in gradients
  • banding in gradients
    Posted by Lensflare1 on June 28, 2006 at 10:58 am
    Hi there.
    Can invig/proanimator create smooth (non banded) gradients.
    I have been flying objects in up close, and you can see the gradients…
    Is it an 8, 16 or float point renderer
    Cheers
    Lensflare
    Lensflare1 replied 20 years, 1 month ago 3 Members · 3 Replies
  • Jon Okerstrom
    June 28, 2006 at 12:57 pm
    Hi Lensflare,
    I haven’t run into the banding issue with either app, but I suppose it’s possible with certain gradients, if the rendering engine is 8 bit. Perhaps Matt will jump in with the tech spec for you.
    The cartoon color rendering option does create banding – a posterization effect – on purpose.
    Jon
  • Matt Rhodes
    June 28, 2006 at 3:35 pm
    Hi Lensflare.
    The current Invigorator/ProAnimator renderer outputs in 8-bit (even though everything internal is done in floating point).
    You may see banding in certain circumstances (when the color variation across a large portion of the screen is minimal),
    but most users won’t see any.
    Now that After Effects supports floating bit output, we’re looking into higher-bit output.
    Stay tuned. And let us know if you have any other questions.
    And, as always, feel free to download a demo of the product to see if it does what you want.
    Matt Rhodes
    Zaxwerks, Inc.
  • Lensflare1
    June 29, 2006 at 4:23 am
    Thanks for that. Float would be great.
    Cheers
    Lensflare
    “That Camel had it coming I tells ya….”
