Activity Forums Adobe After Effects Ball Bouncing again
  • Ball Bouncing again
    Posted by Alessandro Lucchini on April 15, 2011 at 3:32 pm
    Hi all.
    I need to animate a bouncing ball through a maze, with obstacles and so on.
    Everything went ok so far, tweaking Dan Ebberts’s expression about bouncing and squashing that I found here, but when it came to have the ball bounce between a floor and a ceiling, i don’t know what to do.
    Any ideas?
    Thanks.
    Alessandro Lucchini replied 15 years, 4 months ago 2 Members · 4 Replies
  • Jason Mettler
    April 15, 2011 at 4:42 pm
    In the expressions, is there a way to limit the pixel range for top and bottom movement?
  • Alessandro Lucchini
    April 15, 2011 at 4:50 pm
    There’s a “floor” value, which is the y at which the ball bounces up again, but no upper limit. It should be enough finding a way to switch from an absolute cosine like function to some kind of sawtooth, and then back again.
  • Jason Mettler
    April 15, 2011 at 6:35 pm
    Here’s a tutorial that goes over the Sine wave math for AE. It’s quite rambling and he makes a lot of mistakes that get corrected later but, nonetheless, it’s quite informative. You may get some ideas.
    https://twurl.nl/7h6s72
    April 18, 2011 at 9:37 am
    Thank you very much, it won’t be easy but i think i can get some ideas from that.
