Activity Forums Adobe After Effects ball animation
  • ball animation
    Posted by Patricia Contreras on June 8, 2009 at 6:11 pm
    Hi I just want to make the kind of animation they did for this commercial
    https://www.youtube.com/watch?v=eJ1007HkQ68
    I tried to do it with particular but I don’t get it right, could someone can help me with the parameters I have to set in particular, I already have the sphere done and Im using it as an emitter.
    PATRICIA
    Nel Santiago replied 17 years, 3 months ago 2 Members · 2 Replies
  • Nel Santiago
    June 12, 2009 at 4:29 pm
    That looks easy enough to do in a 3D app such as Cinema 4D. You would draw a spline in the shape you would want the main ball to go in. Use the align to spline tag and animate it’s position. This will get the ball moving on a predetermined path. Next Create and emitter, drop on of those spheres into the emitter so that the particles generated are now balls. Scaled to preferred size. You can attach the emitter to the sphere, but I’d suggest using the same align to spline tag. So the emitter can bank. Set your emitter speed to what you’d like and texture the elements.
    That will reproduce what you see in the video. To get it to go behind people, it’s just simple use of mattes in AE. Let me know if that needs further explanation 🙂
    -N
    Site:ForbiddenSky
    Blog:TVNewsBlog
    LinkedIn:Profile
  • Nel Santiago
    June 12, 2009 at 5:28 pm
    https://www.forbiddensky.com/cow/Particles.mov
    https://www.forbiddensky.com/cow/Particles.zip
    This should help explain that better. Disclaimers, disclaimers. Just slapped that together so it’s not fancy, but you’ll get the idea. 🙂
    -N
    Site:ForbiddenSky
    Blog:TVNewsBlog
    LinkedIn:Profile
