Activity Forums Panasonic Cameras balky P2 Store
  • balky P2 Store
    Posted by Bill Nelson on February 8, 2007 at 2:29 am
    Having trouble getting P2 Store to reliably xfer files to my G5 2Gz Dual w/8 gig RAM, Mac OSX 10.4.8
    Using 4′ USB 2.0 high-speed cable, xfer usually locks up, cauing me to force quit at Finder level.
    First tried x-ferring to RAID array, found slightly better luck xferring to large secondary internal drive, THEN to RAID. Either way is tedious and fraught with angst. Am I the only one? Please help if you have this issue.
    HVX200 rolling to Avid MC Soft/SDI Mojo
    Steve replied 19 years, 7 months ago 5 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    February 8, 2007 at 4:13 am
    I will point out that the P2 Genie is a VERY handy application that automates this transfer, creating folders and copying over the footage in the quickest way possible. You can give it a try. $33
    http://www.p2genie.com
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Dean Sensui
    February 8, 2007 at 8:28 pm
    Shane…
    Does P2 Genie solve the occasional problem where the first partition of the P2 Store fails to mount? Or is that something that has to be dealt with via Apple’s Disk Utility?
    Dean Sensui — Imagination Media Hawaii
  • Shane Ross
    February 8, 2007 at 8:38 pm
    P2 Genie is just an application that copies the contents from one location to another, but in a very slick automated way. It won’t help with the mounting issue.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Dean Sensui
    February 8, 2007 at 8:54 pm
    Thanks, Ross.
    Also, it looks like it handles the problem where all the partitions have the same “NoName” label?
    The info on P2 Genie’s website lacks detail, but apparently it’s able to either re-label or sequentially label each partition when copying the P2 Store’s contents over to a Mac-based storage system?
  • Barry Green
    That volumes-not-mounting is a Mac OS quirk; P2 Genie can’t do anything about that. Panasonic has published a paper that’s supposed to demonstrate how to deal with it if not all volumes mount:
    https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/faq/P2store_macmount_e.pdf
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Shane Ross
    February 8, 2007 at 8:57 pm
    [Dean Sensui] “it’s able to either re-label or sequentially label each partition when copying the P2 Store’s contents over to a Mac-based storage system?”
    Yes. It creates folders and give them names you assign (like B001, or Card001) and then copies the information from one partition, then moves to the next creating a new folder (B002, Card002) and so on.
    Looks like I’ll have to review this and blog about it.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Dean Sensui
    February 8, 2007 at 9:09 pm
    [Barry Green] “That volumes-not-mounting is a Mac OS quirk; P2 Genie can’t do anything about that.”
    Thanks, Barry. I figured out the workaround with Disk Utility. As Panasonic points out, it happens with the laptops but generally not with the tower Macs.
    Looks like P2 Genie will be a necessary investment.
  • Steve
    February 13, 2007 at 11:53 am
    Take a look at this product P2 log. Just purchased it, if he can only do the P2 Genie transfer thing multiple copies it is a winner! @ https://www.imagineproducts.com/P2log.htm
    The ability to do the MXF viewing is great, without having to transfer to FCP is great. Other features as well.
