Activity Forums Adobe Premiere Pro balancing speech and background audio etc
  • balancing speech and background audio etc
    Posted by Lorraine Collard on August 11, 2008 at 11:53 pm
    Hi all,
    I have finished my project and now i have concerns that the audio levels might be out. By this i mean some files like background music are at -20, and some speech files are at +3, though it sounds ok through my speakers how do i know it will be ok when its gone through encore. I have exported before and this has happened to me, at certain points the speech is too loud etc. Hope you can help
    lorraine
    Vincent Rosati replied 18 years ago 2 Members · 1 Reply
  • Vincent Rosati
    September 3, 2008 at 12:38 am
    Sorry for the long response time..
    I have an audio rip from a hollywood feature, lots of segments – speech, background music, dramatic music – I import it into all of my projects that are going to DVD.
    By ‘speakers’ I hope you don’t mean headphones, monitoring with headphones will result in a bad mix.
    You should at least have stereo external monitors.
    They should be positioned at ear height.
    They should be spaced equidistant, making a triangle with your head at one point and the left and right audio monitors (speakers) at the other two points.
    If your sound card has an equalizer, set it to flat.
    Good audio mixing is a complicated subject.
    Vince
