Activity Forums Audio Balanced audio?
  • Thaxter Clavemarlton
    February 11, 2008 at 8:34 pm
    Very short runs of unbalanced should be OK, but if you are in the wrong location (strong RF field) you COULD have some problems.
  • Roland Heap
    February 12, 2008 at 9:13 am
    Well, according to Sennheiser spec the output on that 1/8″ jack is balanced, so you should be fine, theoretically up to quite a long cable length.
    I suspect it uses the same pinout as on its larger balanced jack cousins.
  • Ty Ford
    February 12, 2008 at 4:27 pm
    Thanks for that Roland.
    If the plug has two non-conductive bands, it very likely is balanced.
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
    February 12, 2008 at 11:06 pm
    But the camera does not have 1/8″ balanced INPUTS.
    It has XLR mic or line-level inputs.
    And an 1/8″ STEREO (I assume this because it has a built-in stereo mic right next to this input) mic input on the handle.
    If plugged into a stereo 1/8″ input, the balance signal will be ruined.
    OP needs to build or buy a proper cable(s) to connect the mic to the camera.
  • Ty Ford
    February 12, 2008 at 11:22 pm
    Sorry Thax.
    I thought that was a “given.”
    Regards,
    Ty
