Activity Forums Maxon Cinema 4D Baking/Exporting 3D Data with an External Compositing tag via Mograph Fracture
  • Baking/Exporting 3D Data with an External Compositing tag via Mograph Fracture
    Posted by Jeremy Frye on March 12, 2013 at 10:16 pm
    Ok so the subject might be a bit messy – here is the run down.
    I want to use the delay effector by putting my device in a Fracture object and then having the Delay effector effect said device.
    I also have an external compositing tag and compositing tag for the screen of the device.
    When I render it with all the proper channels to get it into After Effects, I don’t get a solid for my screen. When I take it out of the Fracture Object all is well. I put it back in and nothing.
    Anyone come across this or have a work around? I used the MoGraph cache tag with no luck either.
    Jeremy Frye
    https://www.jeremyfrye.com
    Andy Weak replied 12 years, 3 months ago 3 Members · 2 Replies
  • Craig Whitaker
    March 13, 2013 at 6:09 pm
    Have you tried placing the external comp tag on the Fracture? I’m working in a similar setup at the moment with cloners.
    Best,
    Craig
    Craig Whitaker
    Digital Design Director
    Assembly
    161 Leverington Avenue Suite 1002
    Philadelphia, PA 19127
    O: 215-487-2060
    craig@assemblypix.com
  • Andy Weak
    June 9, 2014 at 9:00 pm
    Thanks Craig! Putting the external compositing tag on the fracture object worked for me to get solids to show up in After Effects.
    Much appreciated!
    andy
