Activity Forums Maxon Cinema 4D Baking Question…
  • Baking Question…
    Posted by Ej Hassenfratz on February 19, 2008 at 1:46 am
    So i have this triangle object that has transparency and a light inside of it. In the scene the triangle flies around (the light is inside a null with the triangle) so the light flies around with it. The triangle is interacting with a fw other triangles that are also emitting light of different colors so each triangles lights are interacting with eachother/reflecting/etc…. This is quite a render intensive thing and I was wondering if there was anyway to bake the light that is emitting through the transparent material? Or is this impossible because it’s a moving light?
    ej.hassenfratz
    senior.graphic.designer
    wjla-nc8/eyedesyn.com
    washington.dc
    Ej Hassenfratz replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
