Activity › Forums › Maxon Cinema 4D › Baking Proximal Shader
  • Brian Jones
    August 1, 2014 at 6:18 pm
    yes, it should work with either Bake Texture or Bake Object in the OM/Objects menu – unless you are doing something odd I’m not imagining
  • David Binn
    August 1, 2014 at 6:26 pm
    Hey Brian,
    Thank you for the response! I was also wondering how to bake the animation of the proximal shader, like in a video.
  • Adam Trachtenberg
    August 2, 2014 at 9:23 pm
    The options tab of the bake texture tag allows you to set a frame range for the bake.
