Activity Forums Maxon Cinema 4D baking particles and pyro
  • baking particles and pyro
    Posted by Alan Lacey on October 28, 2005 at 5:36 pm
    Using R9, I’m trying to model a stationary smoke stack in an animated scene.
    I’ve got a decent looking smoke stack using standard particles and pyro but I need to freeze it in 3D as the camera rotates around it.
    Is this possible using ‘bake particles’ or ‘current state to object’ somehow. All my experiments have failed so far.
    Thank you for any help.
    Alan
    Alan Lacey replied 20 years, 10 months ago 3 Members · 5 Replies
  • Brian Jones
    October 28, 2005 at 11:44 pm
    Maybe there is a plugin somewhere to do it (will Fizz stop particles? Not that I can remember). Otherwise, I think you would need to use Thinking Particles so you could set the speed of all particles to zero for as long as needed.
  • Alan Lacey
    October 30, 2005 at 6:45 pm
    Thanks Brian. I do have thinking particles but discovered a plugin from Paul Everett that does just what I want.
    I’ve not tried it with pyro yet.
    Alan
  • Lennart Wåhlin
    October 30, 2005 at 9:58 pm
    And that plugin was…?
    Cheers
    Lennart
  • Brian Jones
    October 31, 2005 at 3:55 am
    Well I worked out a simple example just to do it. So here it is in case it’s useful to someone.
    https://members.shaw.ca/bdjones/PFreeze.zip
  • Alan Lacey
    October 31, 2005 at 6:46 pm
    Cheers
    Lennart
    Paul Everetts.. Matrix Bullet time effect (a coffee script) works brilliantly even with pyrocluster.
    Alan
