Activity Forums Maxon Cinema 4D Baking particle emitter animation for export
  • Baking particle emitter animation for export
    Posted by Hilary Tsai on December 23, 2021 at 11:41 pm
    I’ve tried the two main ways of baking particle animations (particle bake and mograph cache tag on a cloner with emitter as object). I want to export the particles as .obj or .fbx but neither are retaining the baked animation. Is this something that is not supported? Is there a way to ensure the animation bakes out with the particles?
    Kouraib Abdmalek replied 2 years, 12 months ago 3 Members · 3 Replies
  • Mauricio Barrientos
    September 5, 2023 at 11:21 pm
    Hi
    i have the smae problem, how can i export FBX ANIMATION FILE and bake the particles animation please ?
    thanks alot
  • Kouraib Abdmalek
    September 6, 2023 at 10:41 am
    Hi Hillary,
    I suggest that you convert the scene in the form of an Alembic file (ABC) because many of the problems that occur in the animation conversion on FBX do not exist in Alembic, and you will find in the conversion options box many useful options.
    Hope this helps you
  • Kouraib Abdmalek
    September 6, 2023 at 10:44 am
    Hi Mauricio,
    You will find in this the way to bake your animation then you can the conversion properly
    https://www.youtube.com/watch?v=0-Spn5-g3qM&pp=ygUTYmFrZSBhcyBhbGVtYmljIGM0ZA%3D%3D
