Activity › Forums › Maxon Cinema 4D › Baking mograph and thinking particles
  • Baking mograph and thinking particles
    Posted by Michael Goldberg on May 25, 2016 at 1:22 pm
    Hi all,
    There’s been an issue that I haven’t been able to resolve for a while.
    I have a simple setup – Thinking particles being emitted with the surface Emitter preset. It follows a path to another object. All is fine. I then have a cloner set to object with the TP as the object. All is fine. I can cache that cloner for rendering etc.
    The problem – I can’t seem to bake this animation to a mesh for sending to another program. In this case, I need it to go to Unity, which will only take PLA at this moment. I haven’t found a method that works for this.
    Nitrobake – I haven’t been able to get nitrobake to work in v17
    Steadybake – although steady bake works great for cloner objects, it doesn’t seem to work when thinking particles is involved.
    I tried exporting as alembic, and then baking that, but again doesn’t seem to work. Any ideas on this one?
    10119_testbake.c4d.zip
    Mike
    Michael Goldberg replied 10 years, 3 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    May 25, 2016 at 6:38 pm
    I don’t have any problem with Nitrobake in R17. Maybe you don’t have the latest version? Anyway, I was able to bake your file. It took a looong time. Key is that you have to turn off render instances in the cloner. You may be able to use SteadyBake once you turn that off.
  • Michael Goldberg
    May 25, 2016 at 11:28 pm
    Thanks Adam,
    Yes, I tried steady bake with render instances off, didn’t work.
    I coulndn’t get Nitrobake to work in V17, we asked for an updated license key, but never got one. It’s possible Lazaros is busy, or who knows. My v16 key doesn’t work in 17. Oh well, thanks for trying.
    Mike
  • Michael Goldberg
    June 1, 2016 at 3:32 pm
    Yep, Got a new nitrobake key for V17, and it seems to be working.
    Mike
