Activity Forums Maxon Cinema 4D Baking Keyframes to a cinema 4D camera for Export to Maya
  • Baking Keyframes to a cinema 4D camera for Export to Maya
    Posted by Sam Stanton on April 14, 2010 at 8:39 pm
    I have a camera rig set up in Cinema 4d with nulls powered by Xpresso, adjusting the rotation, position, etc.. I have keyframed the Main Null but am needing to export this data to maya. How can i bake the keyframes from the Null to another camera so that maya can interpret the data?
    Sam Stanton replied 16 years, 5 months ago 2 Members · 2 Replies
  • Lennart Wåhlin
    April 14, 2010 at 11:33 pm
    Since your camera is a child of Nulls you need to
    connect its Global Matrix to a second Cameras Global Matrix
    This second camera should be outside your hierarchy
    (and placed last in the OM with no parent).
    Now you can bake this second camera.(Timeline->Functions->Bake Object).
    For export to Maya, try FBX.
    Or get a chan importer for Maya (Google for it)
    and get SteadyCHAN to export a chan file from Cinema.
    If you use SteadyCHAN you only need to select your original camera
    (No Baking or extra camera involved)
    https://www.tcastudios.com -> xfiles -> SteadyCHAN
    Cheers
    Lennart
    aka tcastudios
  • Sam Stanton
    April 15, 2010 at 2:41 pm
    Thanks so much! that worked perfectly!
    sam
