Activity Forums Maxon Cinema 4D Baking in joints
  • Baking in joints
    Posted by Nick Smith on May 8, 2020 at 9:50 pm
    Hi All,
    I’m having an issue I can’t solve without screwing up my models.
    I’ve got some animation loops made using IK and controllers that I need to export for Unity. The problem is, when I export to .fbx that the control mesh comes with it, but if I remove the controllers then the joints won’t move. When I bake in the joints to keyframes the whole model goes crazy.
    It there a way of doing this I’m just missing or a step I haven’t thought of?
    Using R18 btw.
    Nick
    Nick Smith
    \”So long, and thanks for all the fish.\”
    http://www.anarkyanimations.co.uk
    Nick Smith replied 6 years, 3 months ago 2 Members · 2 Replies
  • Sam Treadway
    May 9, 2020 at 4:49 am
    Middle click select the entire joint hierarchy in the object manager.
    Open up the Timeline and in the Timeline’s menu goto Edit > Selection > Select all Objects
    Then in the menu goto Functions > Bake Objects.
    Make sure to select ‘Create Copy’ and ‘Clean Tracks’ and then any parameter sets needed.
    Export the copy using the file menu within the Object manager.
  • Nick Smith
    May 9, 2020 at 8:54 am
    Hi Sam,
    Thanks for the help.
    Strangely enough it was having those ticked that was messing with the model. I unticked them and everything worked fine.
    Thanks though 🙂
    Nick Smith
