Activity Forums Adobe After Effects Expressions Baking Expression Selector?
  • Baking Expression Selector?
    Posted by Joe Richardson on April 14, 2020 at 9:30 pm
    Hello,
    I made a series of Expression Selectors filled with REGEX to do color fills for syntax highlighting. However, they take a long time to render — and I was wondering if there was a special way to bake the colors derived from the expression selectors into the text?
    I’ve tried converting everything into keyframes, but the colors always revert back to their defaults.
    Joe Richardson replied 6 years, 4 months ago 2 Members · 2 Replies
  • Andrei Popa
    April 15, 2020 at 6:49 am
    If you don’t need to change them afterwards, you could run a script and make them keyframes directly.
    But if you change the text afterwards, you may get some unpleasant results.
    If you want the text to also be responsive, you have no alternative. Maybe just optimize your expression. Complicated regex can be computational heavy.
    Andrei
    My Envato portfolio.
  • Joe Richardson
    April 17, 2020 at 12:59 am
    All right. Thank you.
    I contacted Zack Lovatt who created a plugin to do just this type of thing, and he mentioned that it’s not possible to bake the expression animator.
