Activity Forums Maxon Cinema 4D Baking dynamics animation for Element 3d v2 (After Effects)
  • Baking dynamics animation for Element 3d v2 (After Effects)
    Posted by Justin Rogers on April 7, 2017 at 6:21 pm
    Hi all
    I’m having problems importing a C4D animation into After Effects Element 3D. The objects area all converted to mesh, the animations are baked using standard bake (plus I’ve tried SteadyBake and KeyMate plugins) I’ve also set the Output range to All Frames.
    Howvere, when I import the .c4d file into Element 3D v2 (ensuring to check the ‘Load Animation’ box) it only shows one frame. Could someone kindly help me out, going a bit nuts.
    Justin Rogers replied 9 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
