Activity Forums Maxon Cinema 4D baking cloth nurbs
  • baking cloth nurbs
    Posted by Alan Lacey on August 14, 2006 at 3:13 pm
    I’ve made a thick ‘cloth nurbs’ that moves, bends and tears as I need, now I want to map separate materials to the back and front faces. The front will be semi trasparent showing the one on the back through a little.
    The ‘bake object’ command is greyed out on the cloth nurbs object, and all of it’s sub objects, is there a way of baking this motion, so that I can create the necessary face sub-selections for the relevant materials? Making the cloth nurbs editable looses all the motion.
    With many thanks
    Alan
    c4d 9.6
    Alan Lacey replied 20 years, 1 month ago 3 Members · 6 Replies
  • Björn Marl
    August 14, 2006 at 6:10 pm
    Cloth has it’s own caching function, just take a lok at the cloth tags cache tab.
    Cheers
    Bj
  • Alan Lacey
    August 15, 2006 at 4:18 pm
    Yes, of course thanks Bjorn. Hell, why didn’t that occur to me?
    Alan
  • Simon Carlson-thies
    August 15, 2006 at 10:04 pm
    There is another solution to the problem go into Mocca and Cappuccino, select PLA only and select start real time on your cloth object not the nurbs object select point editing mode deselect all, click any where in the frame just make sure you don’t move the cloth at all. Then when your finished delete the cloth tag and do what ever you want, just remember the motion is set now and is very hard to change…
    Simon Carlson-Thies,
    Digital Light Graphics And Animation
  • Alan Lacey
    August 16, 2006 at 7:21 am
    That’s the sort of solution that was going through my mind but I don’t know c4d well enough to impliment it, thanks a lot Simon I’ll give that a go too.
    Alan
  • Björn Marl
    August 16, 2006 at 8:55 am
    Thats the brilliant thing about the cloth cache. There is the cloth cache tools that allows for easy modification of the cached solution.
    Cheers
    Bj
  • Alan Lacey
    August 16, 2006 at 2:33 pm
    Agreed, sounds brilliant.
    Alan
