Activity Forums Adobe After Effects Expressions “baking” child keyframes
  • “baking” child keyframes
    Posted by Alan Parma on August 17, 2006 at 7:56 am
    hi,
    i’m using an expression that enables a lens flare to track a 3D object
    thisComp.layer(“Light 1”).toComp([0,0,0]);
    however, my “Light 1” layer is parented to another layer, and apparently this whole thing doesn’t work because the Light 1 layer is a child, and only the parent is moving. what happens is if the parent moves, the child moves, but the lensflare stays put because it doesn’t “see” the child moving. is there a way to keyframe the child’s movements in relation to the parent’s motion so that the lensflare can track the child?
    hope this makes sense.
    Dan Ebberts
    replied 20 years, 1 month ago
    3 Members · 2 Replies
  • Mark
    August 17, 2006 at 10:35 am
    Could you not add an expression where the filters position is tied to the position of the parent, and not the position of the layer tied to the parent.
    Mark
  • Dan Ebberts
    August 17, 2006 at 6:02 pm
    That expression should work fine (even with the light being a child). There must be more to the story…..
    Dan
