Activity › Forums › Maxon Cinema 4D › Baking
  • Posted by Randy Johnson on September 26, 2007 at 10:49 am
    Can some one clarify to me how to bake AO into a material so I dont have to render it every frame…I have seen a tutorial about doing this with GI and it brought up a little AO but I am not wanting to do it a Multi render.
    I have a still camera and a still clock and the hand moves. I have tried a few settings with baking the AO but I really dont know what setting does what and I kept destroying my textures.
    I have post the file that I am working on here
    http://www.randyarchy.com/clockzip.zip
    (I know it is not the most econimical model but since this the entire scene I am not worried about it.)
    Randy
    Randy Johnson replied 19 years ago 2 Members · 2 Replies
  • Brian Jones
    September 27, 2007 at 2:23 pm
    -turn off the global AO in the render settings
    -apply AO object by object in the Diffusion channel of each objects material
    -floor, watch body, face and date (face and date need to have evaluate transparency turned on)
    -don’t put it on the hands or transparent bits
    -lower the face and date AO samples and accuracy (I did 64 and 70%) and it renders in 1/3 the time.
    …of course if you’re baking keep the samples up if you want
    -select an object to bake and Render/Bake Texture (probably you need to join hoop, hoop ontop and body to get one bake since they use the same texture)
    -replace the AO in the Diffusion channel with the generated bake image.
    for the face either:
    -turn off the hands and bake or
    -bake a series of images so the AO follows the hands as they animate
    And a critique – with AO the face looks old and used but the body looks new
  • Randy Johnson
    September 28, 2007 at 6:37 am
    That is perfect, Thank you .
    I am still playing with the body texture…I wasnt sure if I would catch on to the baking thing in time so if this failed I didnt have to make any changes.
    Thanks again.
    /randy
