Activity Forums Maxon Cinema 4D Baked Textures – C4D
  • Baked Textures – C4D
    Posted by Charlie Bartlett on February 7, 2012 at 3:41 am
    Hello wanted to get some advice on best practice (I am two weeks into learning this so please bear with me)
    I have (for days) now tried to bake textures for a model and normally I wouldn’t have to do this but it’s for a specific project that I am exporting via Collada 1.4 so I need to replace textures in the Color channel.
    However, I am getting a grainy mess for the bake and have tried multiple areas/combinations to resolve it so wonder if anybody had some best practice in case I am missing something v.obvious. Shadow map is fine, but it’s the bake on the Surface Color +/ or Illumination that is flawed.
    Things I have tried to resolve it in the various combinations:
    Texture
    Texture used – Sampling tried both SAT and MIP (Sat for Flooring) – no avail
    Set a Blur Offset to 20% for Floor – no avail
    Texture Size increased from 1024 x 1024 to 4096 to 4096 (not ideal and not enough of a fix – marginally better)
    Bake Tag
    Optimal Mapping – set to Cubic and not – no avail
    Format Tiff and PSD – no avail
    Color Depth, tried 8 and 16 – no avail
    Size 1024 up to 4096 again and matched the texture – no avail
    SuperSampling 0 through to 10! (ouch on timing)
    Pixel Border 1 through to 6 – no avail
    UVW Map
    First used Cubic 2 and and set a new layer for the map – then applied texture per my UVW map etc – no avail.
    I then tried some various options including LSCM for relax and then setting Optimal Cubic Mapping to match in the Bake Tag on that occasion.
    Then manually unmapped myself – no avail.
    My scene only has Environment (physical sky and Sun) defaults – could it be lighting (my renders are perfect in application and I know the GI aspect with baker doesn’t work)
    I have watched every tutorial I can find but as yet nothing to pinpont where I am going wrong so hoping you guys can give me some pointers. Thanks 🙂
    Stephen Wicklund replied 13 years, 3 months ago 2 Members · 1 Reply
  • Stephen Wicklund
    February 16, 2013 at 12:00 am
    I have exactly the same problem. And apparently this guy does too: “https://forum.unity3d.com/threads/35276-cinema-4d-baking”
    No solutions I’ve found yet.
