Activity Forums Maxon Cinema 4D Baked object shows question mark on texture
  • Baked object shows question mark on texture
    Posted by Hilary Tsai on July 11, 2020 at 8:28 pm
    I have a simple extruded object that I used Bake Object on, (it’s just a simple texture using only the color channel). When I hit ‘bake’, it creates my new baked object with a question mark over the texture. I’ve tried making the current state to object and making it editable to see if it makes a difference when I bake. But it’s still the same result. However, when I try the same process with just a cube, it works fine and the texture is maintained. What could the problem with baking an extruded shape be?
    Jim Scott replied 6 years, 2 months ago 2 Members · 3 Replies
  • Jim Scott
    July 11, 2020 at 9:48 pm
    If you expand the Extrude.1 null you should see the material on the enclosed Extrude:
  • Hilary Tsai
    July 15, 2020 at 10:30 pm
    Thank you, Jim! You are right, the textures were all inside the null. However, there were some texture issues upon importing the model into Mozilla Spoke, which I assumed had to do with the question mark–but I’m likely wrong (and this may be a topic for the Mozilla forum, so I may try there). Thank you so much for replicating this issue!
  • Jim Scott
    July 15, 2020 at 10:47 pm
    Glad I could help. Thanks for reporting back.
