Activity Forums Maxon Cinema 4D Bake Jiggle deformation
  • Bake Jiggle deformation
    Posted by Seth Olson on October 27, 2016 at 8:45 pm
    Hey!
    So, I’ve got a platonic that has a random scaling with Jiggle. It looks great, now I want to clone it. I tried a Point Cache, which makes the distortion permanent, but when i clone and use a Shader Effector and offset the time, the animation does not shift. It is as if the point cache ignores the time shifting. If I don’t point cache, and just leave the Jiggle, no distortion comes through the cloner at all.
    Suggestions?
    R14, btw. Thanks!
    Seth Olson replied 9 years, 4 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    October 28, 2016 at 2:47 pm
    You can bake the jiggle deformer to point-level animation (PLA) by selecting the object that’s being jiggled in the Timeline and running the Functions>Bake command with PLA enabled. Then the offset should work.
  • Seth Olson
    November 2, 2016 at 2:48 pm
    That did the trick, thank you so much!
  • Pravin Chottera
    March 31, 2017 at 10:30 pm
    Trying the same thing, but I must be missing something.
    When I bake the object (select object – -function – bake – check pla), it just creates a copy of the object with the same jiggle deformer. When I disable the jiggle on the new object, there is no pla.
    Below is a sceencap of what I’m doing.
    Scene file here: 11203_jiggletest.c4d.zip
    Thanks in advance!
  • Seth Olson
    March 31, 2017 at 10:55 pm
    first guess: it looks like the torus is a procedural object. try making it a polygon first by making it editable. then apply your dynamics and bake process.
