Activity Forums Maxon Cinema 4D Bake Ambient Occlusion with IvyGrower
  • Bake Ambient Occlusion with IvyGrower
    Posted by Chris Wood on April 24, 2012 at 10:52 am
    Hello, sorry for another post, but I’m having another problem.
    I’m trying to bake AO in my IvyGrower plugin as without AO, the Ivy looks unnatural. With AO, it looks great but each frame is 3 minutes (270 frames total) and as it’s a totally static object, why not bake it and save myself hours?
    So I have the object with its green leaf textures and brown branch textures, I turn AO on, select the Ivy and go to Render>Bake Object.
    I select Ambient Occlusion, then choose .PNG and select where to put the baked textures.
    I hit bake, and it seems to work, it goes through all the objects.
    My problem is that once its finished, it’s duplicated my objects and hidden the originals with the correct textures. The new objects have black textures which I assume is the AO.
    How do I get my original textures back onto the object, WITH the AO still applied?
    Thank you.
    Chris Wood replied 14 years, 4 months ago 2 Members · 6 Replies
  • Brian Jones
    April 25, 2012 at 3:25 am
    how big did you make the texture? In the ivy object all the leaves are one object (well, one for the young leaves and one for the old leaves) and one texture map has to cover the whole surface area of all those leaves, so it would have to be big enough for detail. That goes for the color and the AO. It might be better to check out the help for AO and tweak the settings for speed (unless you are there already)
  • Chris Wood
    April 26, 2012 at 12:34 am
    Sorry, I’m not following you for what I should do here.
    I emailed the guy who made it and he got back to me with this:
    “Hello Chris,
    A couple of things to help bake the ambient occlusion:
    * Add Ambient Occlusion to your Render settings (under Effects).
    * Enable Diffusion on the Materials and set the Texture to Ambient Occlusion (under Effects again).
    * On the Bake Texture tag, enable Ambient Occlusion, set SuperSampling to 1, set Background to black.
    I went with the default 256×256 in PSD format but you can try different sizes and formats.
    After you bake the texture, replace the Ambient Occlusion shader on the Diffusion channel with the resulting baked file. You can also disable Ambient Occlusion in your Render settings at this point. This greatly improves render times.”
    This seems to be a step in the right direction, however, it still looks nothing like actual AO, and still has weird glitches over some of the textures.
  • Brian Jones
    April 26, 2012 at 4:59 pm
    Don’t have time to test but Baking has a bunch of settings which will change things and I’m most familiar with baking when it moved from the Render Menu, either the Bake Texture tag or Bake Object in the Object menu (12 and 13?). Either way regardless of other settings baking will produce (at least with the ivy leaf objects) one of two kinds of images. If you include all the layers available with one method you get what looks like one leaf which since that is how the leaves are being done (single image provides the colour for all the leaves) looks fine but the AO (or diffusion channel) is having to be used for all the leaves so it can’t be right to use the same AO for everything. The other method gives you an UVW mapped image that has many leaves on it, the individual leaves in the image are UVW mapped to an individual leaf in the leaf object and potentially could have the correct AO across one leaf but for this one image to have the correct detail for so many leaves means it has to be *huge*. It takes a lot longer to make an image that size and it might be quicker to just render with AO, so that’s why I thought it might be better to just use AO in the diffusion channel of the leaf objects and tweak the settings of the AO for speed.
  • Chris Wood
    April 27, 2012 at 12:06 am
    I broke down and rendered with AO on for one of the scenes (1:10 seconds for 137 frames which isn’t too bad) but I have another scene with 280 frames, 6-7 minutes per frame, which is very bad.. Over a day of rendering. My PC will asplode!
    I’ve been trying to get this to work nearly all day and just can’t. Surely there’s an easier way? Rendering AO just the once is 6 minutes. After that there’s no change on the texture as its just the cameras perspective that’s changing.
    Thank you.
  • Brian Jones
    April 27, 2012 at 3:26 am
    I don’t think you can bake AO successfully with this object, it works great most of the time and it would work great if the leaves were all separate objects (thousands of them with thousands of separate textures)…
    The quickest render method I can think of that would be sort of appropriate would be to use Fresnel (you’d want to invert the knots in the fresnel so it was black on the left of the gradient and white on the right) in the Diffusion channel instead of AO, the result would not be as ‘real’ as AO but would give you, hopefully, the leaf definition you are looking for.
  • Chris Wood
    April 28, 2012 at 12:12 pm
    I’ll give Fresnel a try then, thank you.
    Yeah it’s just the main thing of trying to make the leaves look more real, that’s all.
