Activity Forums Adobe After Effects Expressions Bake All Expressions in Comp?
  • Dan Ebberts
    January 19, 2015 at 10:34 pm
    If it’s just Orientation, I think this will work (assuming you have the comp active):
    var myComp = app.project.activeItem;
    for (var i = 1; i <= myComp.numLayers; i++){
    myComp.layer(i).selected = false;
    var myProp;
    try{
    myProp = myComp.layer(i).property("Orientation");
    if (myProp.expressions != ""){
    myProp.selected = true;
    app.executeCommand(app.findMenuCommandId("Convert Expression to Keyframes"));
    }catch(err){
    Dan
  • Lukasz Pason
    January 19, 2015 at 10:41 pm
    Worked like a charm. Thank you Dan! I can use this with any property, yes? What a time saver!
    Motion Designer / DJ / Father
    http://www.lukaszpason.com
    http://www.krop.com/lukasz
  • Dan Ebberts
    January 19, 2015 at 10:48 pm
    Well, you’d have to edit the property name in the script. Having it work for any property with an expression would require a more complex script.
    Dan
  • Lukasz Pason
    January 19, 2015 at 10:49 pm
    Thanks again Mr. Mad Scientist. =)
  • Chris Scalzo
    December 11, 2019 at 9:04 pm
    If I used this to bake sourcetext that I populated from expressions, it there any way to turn off keyframing on the text layers since every frame would be the same value? I know I can go through hundreds of layers and click the stopwatch.
    Thanks in advance, I realize this is a 5 year old post.
