Activity Forums Maxon Cinema 4D Bake align to spline to postion/rotation
  • Bake align to spline to postion/rotation
    Posted by David Biederbeck on December 2, 2011 at 4:34 am
    I have a light flowing along a spline with an align to spline tag. I plan on using it to spiral the object with particular in AE but I’m having trouble adding the baked data to the light. consequently my light only has two keyframes in after effects,
    Anyone have a suggestion? Or is there an easier way?
    Richard Dunstan replied 14 years, 9 months ago 2 Members · 2 Replies
  • David Biederbeck
    December 2, 2011 at 4:37 am
    PS, I found this….
    https://forums.creativecow.net/thread/19/864833
    Which works in cinema, but is still not compositing in after effects with movement.
  • Richard Dunstan
    December 2, 2011 at 3:20 pm
    just add an external compositing tag to your light, in render settings make sure you have everything under “compositing project file” and click save. if you just need position data you won’t need to render, open the .aec file with ae and you will have all the position frame by frame.
