Activity Forums Apple Final Cut Pro Legacy Baffled about dropped frames on capture.
  • Baffled about dropped frames on capture.
    Posted by Matt Callac on September 19, 2006 at 3:48 pm
    We have an old G4 Dual 800 that we have been using on the side of our main FCP suite to do client dvd’s and things of that nature. A couple months ago, I updated the OS and bumped it up to final cut 5. Ever since then we have been unable to capture anything over about 15 min in length. We capture to an internal media drive that is NOT the system drive. It is only about 25% full. We only work in DV on this system as we usually bring things in through a DA-Max. We’ve tried multiple different variations of capturing now as well as capturing large duration clips, coming off of VHS/Beta/Digibeta (with machine control/timecode) as well as trying to bypass the Da-max and load striaght DV off of a JVC DR-DV300. Every time though it drops frames after about 15-20 min of capture. Before the Update we had captured hour long things to the very same drive. The media drive is formatted as mac os extended (no journaling enabled). And on the Update of the OS and FCP, I wiped everything clean.. Any ideas about why we are having this problem.
    Thanks in advance.
    Machine specs: G4 Dual 800; 2gb ram ; tiger 10.4.6 ; Final cut 5.0.4
    -mattyc
    Matt Callac replied 20 years ago 4 Members · 5 Replies
  • Frank Nolan
    September 19, 2006 at 4:31 pm
    How full is your system drive?
  • Matt Callac
    September 19, 2006 at 4:42 pm
    70% of the system drive is free.
    -mattyc
  • Kevin Reiner
    September 19, 2006 at 6:12 pm
    We seem to be having the same problem. We have 2 machines attached to an Xraid via a Qlogic fibre switch and using Fiberjet. We have made a couple of updates lately – iTunes, QT, Xraid firmware, AJA software. We are beating our heads against the wall trying get it to work. Let me know if you figure out anything, and I’ll do the same.
    Machine specs: Dual 2.7 GHz PowerPC G5; 6.5gb ram ; tiger 10.4.7 ; Final cut 5.0.4
    -Reins
  • Kevin Monahan
    September 19, 2006 at 6:33 pm
    Bypass the DAMax AND the JVC deck. Go with a Sony and see what happens. JVC’s are at the heart of many problems.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Matt Callac
    September 19, 2006 at 7:08 pm
    The only DV deck we have is the JVC. We dont’ actually use it for doing production stuff, we just have it b/c we have a dubbing facility as well. I just used it to test and make sure that it wasn’t the DA-max causing the problem. I’ll have to try and borrow a Sony to see if that’ll work.
    mattyc
