Activity › Forums › Apple Final Cut Pro Legacy › Bad/blurred/jumpy motion graphics after export in FCP
  • Bad/blurred/jumpy motion graphics after export in FCP
    Posted by Ashley Vonclausburg on February 27, 2012 at 4:58 pm
    Hi all,
    I posted this a week or so ago but didn’t get a response, so I thought I’d give it one more shot, as I’m still at a loss!
    I’m not a video professional by any means, but am putting together a short video for my company that is mostly high-res images, motion graphics, and text, with a bit of video.
    All of the Motion graphics and sequence settings are 1920×1080, XDCAM EX 1080i50 – the same settings at the short video clips that are included. However the quality of the graphics look really bad on export. Particularly the opening title sequence and a series of pictures that move across the screen.
    I tried just exporting it as a QT movie with all of the current settings and everything is blurred and not clean-looking. (As seen here: https://www.youtube.com/watch?v=ChQiOpcOltU
    I also tried exporting using QT conversion with H.264 compression, 1920×1080 HD. The graphics look cleaner but there were white lines through anything that moves across the screen. I did check deinterlace source video.
    This video will mostly likely be used just as an embedded video on a website through youtube, but may be played over a projector on a large screen at some point.
    Once again, any and all feedback would be more than appreciated!!
    -Ashely
    Shane Ross replied 14 years, 7 months ago 2 Members · 5 Replies
  • Shane Ross
    February 27, 2012 at 5:50 pm
    Use a ProRes sequence. XDCAM is a GOP format that is lossy, and doesn’t really have a solid frame rate. meaning that there are only a few real frames, and the rest in between is all guesswork. VERY GOOD guess work, but not I Frame like ProRes.
    Make a new sequence…ProRes 422…copy and paste the footage into it. Render. Then look.
    Shane
    Little Frog Post
  • Ashley Vonclausburg
    February 27, 2012 at 6:35 pm
    Hi Shane,
    Thanks so much for the quick feedback! Once I put it in the new sequence, how should I export it? Just as a QT movie, with all the settings the same?
    Thanks again!!
    -Ashley
  • Shane Ross
    February 27, 2012 at 6:58 pm
    [Ashley vonClausburg] ” how should I export it? Just as a QT movie, with all the settings the same?
    Exactly.
    Shane
    Little Frog Post
    February 28, 2012 at 2:28 pm
    Hi Shane,
    Thank you so much for your help! I’m sorry to bug you again but I tried having the sequence set up the way you outlined, and I’m still getting the same result (blurred, jagged movement) as seen here in the opening and at 27 seconds https://www.youtube.com/watch?v=LawmYZteW3U
    Is it possible there is a problem with my Motion project settings for those two graphics? They are both:
    XDCAM EX 1080i50
    1920×1080
    25fps
    The sequence setting in FCP is:
    1920×1080 HDTV1080i
    Editing time base: 25
    Compressor: Apple ProRes 422
    Because I changed the compressor in FCP should I also change it in my motion projects?
    Your help is beyond appreciated!! I am absolutely as lost as I seem 🙂
    -Ashely
  • Shane Ross
    February 28, 2012 at 5:51 pm
    Use ProREs in your Motion Projects…not XDCAM.
    Shane
    Little Frog Post
